Brief Description: Wings-Placed spars in the stands and attached ribs
Starting to look like something now! The wing kit I bought already had some work done on the ribs and spars, all the plate nuts were installed and the ribs were primed. I drilled the hole for the conduit run, although I did mess up 3 holes, cleaned up some rivets and cleco'd everything. The ribs are very confusing with their nomenclature. The part number is W-710/11 or 12 with either L or R suffix. One would assume the L meant left and R meant right, not so, that how I drilled the 3 ribs on the wrong side. Oh well.
