Brief Description: Continued work on the wing stands
I completed one set of stands enough to test fit the front spar and some ribs. I stil need to build the supports for the rear spar and the supports for the other set.
The wing kit I purchased was supposed to only have the fuel tank stiffeners installed however after opening things up I realized the spars had been started. The quality of work is not the best so I may have to redo some of it.
