Riveted baggage door hinge to fwd frame of door and skin. Riveted remaining frames and door lock bracket to skin and frame. Installed baggage door lock assembly. Installed soundproofing material then riveted closeout panel to door. Final drilled hinge frame then deburred and dimpled. Clecoed frame to mid side skin then match drilled upper and lower tabs #30 to floor and seatback brace. Positioned baggage door assy into opening then match drilled two holes to hinge frame as per plans. Removed door and hinge frame then clecoed frame to hinge and match drilled remaining holes. Countersunk hinge for an3 rivets. After priming riveted hinge to frame.
