Brief Description: Rear seat pans and baggage floors
Clecoed L&R rear seat pans in place then match drilled all holes per plans. Fabricated L&R rear seat back hinges per plans then located on fwd edge of baggage floors and match drilled. Clecoed baggage floors and set back hinges in place. Final drilled #40 holes in F1023B baggage floor angles and dimpled as shown then clecoed in place. Final drilled baggage floors, angles and seat hinges per plans. Final drilled #40 baggage door shim and lower door seal channel then dimpled all holes. Clecoed baggage door shim and lower channel to side skins and baggage floors then match drilled #30 holes as required. Trimmed door lock opening from upper baggage door seal channel as shown then final drilled #30 holes. Clecoed upper baggage door seal channel to F1006 bulkheads and match drilled per plans.
