Brief Description: Elevator bellcrank and sheardeck riveting
Riveted the rudder stop skin stiffeners to side skins and to stop brace on bulkhead. Installed nutplates on elevator bellcrank rib angles then riveted angles to left and right bellcrank ribs. Riveted both bellcrank rib assemblies to F-1007 frame and bottom skin. Riveted side skins to longerons in area below sheardeck. Riveted shear deck and support angles as indicated. Riveted F-1009 frame to shear deck.
