Brief Description: Skin and stiffener installation
Placed bottom skin upside down on sawhorses and clecoed in place frames F1007, F1008, and F1010. Installed bottom skin stiffeners F1047 L,R and G then aligned centerline mark as indicated with rivet rows in bottom skin and match drilled with #40. Clecoed the F1029L-R bellcrank ribs in place to skin and F1007 frame and final drilled the common holes to ribs and frame with #30. Positioned right side J-stiffeners in bulkhead notches then clecoed thr right side skin in place. Centered the stringer edge marks in rivet rows an side skin and match drilled the F1047C,D and E stiffeners with #40. Flippeed assembly over to allow for left side skin and stringer installation.
