Brief Description: Bulkhead fabrication, longerons and stringers
De-burred and fluted as required the F1006, F1007, F1008 bulkhead frames. Match drilled all common holes of frame sections with #30 drill. Enlarged the two rudder cable holes in frame F1007 with unibit to 5/8" as indicated. Marked all J-stiffeners as indicated with edge marking tool. Bent R-L longerons 2 degrees down as shown on plans to match side skins.
