RV-10 N73GF
Date:  3-11-2017
Number of Hours:  7.00
Manual Reference:  9-14,15
Brief Description:  Riveting trailing edge and rolling L.E.
Removed clecos from trailing edge and cleaned sealant from holes and dimples.
Using the same instructions as the rudder riveted the trailing edge of both elevators with flat rivet set and backriveting plate using about 45 psi.
Finished riveting skins aft of rear spar.riveted inboard shear clip to skins with blind rivets as shown.
Made a slight bend in leading edge of top skin using edge rolling tool.
Using 1 1/4" pipe rolled leading edges of both elevators one section at a time.
Clecoed leading edges together and final drilled with #30 drill.
Removed clecos and deburred holes. Secured with rivets as indicated.
Riveted trailing edge
Rolling L.E. with 1 1/4
Rolling L.E. with 1 1/4" pipe
L.E. finished
L.E. finished
