Using Dynon's instructions mounted roll servo with brackets and hardware provided. Installed travel limiting bracket behind servo drive arm. Set bellcrank to neutral position and adjusted servo link rod as required then installed and saftied all hardware. Installed and secured conduit and connector standoff then installed servo harness wiring and Dsub connector.
