Brief Description: Wing attachment and wing root panels
Temporarily installed wings. Clecoed, clamped then drilled rear spar attachments. Clecoed wing root fairing supports in place. Trimmed upper and lower wing root fairing as required. Final drilled fairings for #8 screws then removed, deburred and dimpled attach holes. Countersunk tank attach bracket for dimples and dimpled tank skin for #8 screws per plans. Installed wing root fairing attachment nutplates as required then temporarily installed fairings to check for proper fit.
