Temporarily pop riveted the boot cowl skin in place so that the top center section skin would lay in place. I cut the skin to fit and then drilled the channels. I don't have the hinges, so I put an order into Spruce for those, and some other stuff I needed. I'll match drill the hinges when I get them. Also started trying to figure out how I was going to get the induction air into the rear facing induction on the throttle body. Not sure.
