Greg's Bearhawk Build
Date: 12-12-2015
Number of Hours: 3.50
Brief Description: Pieces of the puzzle
First, I set some mouse traps. I was working yesterday on my gun, and out of the corner of my eye I saw movement. I looked again and a couple of mice were scurrying about. Then I went about fitting the various parts that Tom had worked on. Got most of them in place, including the instrument panel blank. Measured out a skyview on it to make sure I have room. I may have to go with the smaller size, or live with one large one towards the centerline, and a smaller engine monitor backup on the cp side. Discovered two of each side of the boot cowl skins. Not sure which ones to use, Put a text into Tom, but maybe his number has changed. Everything looked pretty good, but I have a bunch of holes to drill, debur, dimple and rivet. Metal work I can deal with. Toying with modifying a RV 7 or 14 cowling instead of the tin one in most bearhawks. It's a thousand bucks, plus time modifying it to fit. I dunno.
turn your head to the left...
