Drilled and cleco'd center panel of dash to strenthen it a bit. Previous bulder had plans to use screws up there on the corners for behind the panel access, but I'm going to use a hinged panel so I won't need that. Going with rivets instead. Also cut out naca ducts for front seat ventilation, and while I had them off the plane, trimmed up some places that would have rubbed. Cleaned up all the edges, deburred them and took off all that damn plastic.
