Construction Of the Europa XS
Europa XS
Rigged Aircraft
7-1-2009
Checking Setup
I wanted to set the Aircraft up to check that everything Is fitting good and straight before I start filling and sanding (Gulp!!!)
Port
FWD
STBD Stright as an arrow
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
