Construction Of the Europa XS
Europa XS
Cockpit Module
1-5-2008
Fuel Tank Lay-up 2 & 3
This lay-up of BID is to support the tank in the saddle area and on either side to take the weight of the fuel tank and to transfer it into the rear bulkhead. It is made in the same way as the other tank lay-up to form a âTâ shaped bracket.
Saddle Area
Europa XS Home
1209
Aft Area
Aileron
Cockpit Module
Electrics
Filling Process
Flaps
FWF
In The Cockpit
Instruments
Kit Collection
Mods
Port Wing
Rigged Aircraft
STBD Wing
Tailplanes
Wing Fitting
Workshop
