Construction Of the Europa XS
Date:  2-22-2009
Number of Hours:  3.50
Brief Description:  Tail Plane Retention Mod
Continued some work on the tail plane retention Mod. After the ply layups had been inspected by Graham. I could proceed and fill the holes on the underside. A block of foam is cut to size. It is fitted in and bonded after cutting the drainage hole. I used a plastic ½” tube for this. 3 Ply’s of bid are then laid over the top onto the surface. All ready for filling and sanding now.
Foam Block
Foam Block
Layups
Layups
Compleat
Compleat
