Construction Of the Europa XS
Date:  8-15-2008
Number of Hours:  3.50
Brief Description:  Torque Tube 2
After the first setup, and you are happy with the tube, A fixing mix of Redux is used to secure the Tube bushes in place. I cut out some peel-ply to get a nice finish on the Redux.
I decided to use a clamp modification to the tube instead of the usual way, This saves drilling the nylon bushes and give an all-round better and safer construction to the Torque Tube. Doing the mod prevents any possible movement developing and also allows the removal of the Torque Tube easy if required. All the credit goes to Pat Tunney who’s website can be found at
http://www.europaxs.com/
The clamps have to be made to each individual Torque Tube, as they may very in dimensions.
It makes setting up the Torque Tube very easy and it all fits together like a glove.
Clamps
Clamps
