Brief Description: Horizontal Stabilizer Is Complete 2
The bottom of the stabilizer is complete and all rivets look fine to me. One thing for sure, is that the hand squeezer sure gives you hands a work out.
For the top side order, I did different after reading a fellow -8 builder log. I started of the tip, HS-706, and then moved to the inboard side, HS-404 and HS-405. I left the the rear spar to the very last
The last four rivets that go in are bind or pulled rivets. Below is the two last rivets set for the horizontal Stabilizer.
