Michaels RV-8
Date:  6-1-2013
Number of Hours:  3.00
Brief Description:  Horizontal Stabilizer Is Complete 1
Starting on the bottom side of the left stabilizer, I used the hand squeezer to rivet the skin to the rear spar. I started at the inboard side and worked my way to the tip.
All rivets along the rear spar have been set. The bottom right side is next.
After the right side was complete, I went back and riveted the HS-706, HS-404 and HS-405 on each side.
