Brief Description: Horizontal Stabilzer is Almost Complete 2
The manual does not tell you the sequence in which to install the rivets, the video I purchased from Van's tell you to start at the intersection and work up and out. So I did.
The rear spar sub assembly is the last part that gets Clecoed on. The rivets that fasten the HS-405 and HS-706 get installed first, the new tungsten bucking bar and rivet gun works best as these are AN470AD4 rivets and I find them hard to hand squeeze them.
