Brief Description: Horizontal Stabilzer is Almost Complete 1
Once you get the left side skin riveted to the HS-702, front spar its time to get the right side Skin Clecoed to the HS-702, HS-706, HS-707 and then the HS-708. I found that it was easier to do with the assembly laying flat on the table with a foam pad on each side.
Below is the bottom of the right side all Clecoed and ready the start bucking rivets along the front spar. Note the green tips on the two rivets that get a longer rivet than all the others. HS-702 gets riveted to the tip rib, HS-706 before you start the rivets along the front spar.
The HS -708 gets three "blind" rivets that fasten it to the front spar, HS-702 and the nose rib, HS-707 which you cannot see nor get to, hence having to use the blind rivets.
