Brief Description: Pre-Assembly of Left Horizontal Stabilzer 2
Once you turn over the assembly,you finish riveting HS-707 the the skin using AN426AD3-3.5 rivets. I elected to place those same rivets on the bottom side as it was not a too tight of a squeeze to get and hand and the bucking bar inside the area.
Below is the left side completely Clecoed, ready for the riveting process.
