Jasons Thatcher buildlog
Date:  11-21-2015
Number of Hours:  3.00
Brief Description:  Notching tube for engine mount
Used a tubing coping calculator on the web to create cut profiles for the 4 angles in the mount. I would slip the template on, mark the edge with a sharpie marker and grind. They came out great but the upper left fuselage mount is tricky cause they have to be ground to miss each other as well as fit the bolt tube. That was done by eye.
