After Jake Janson inspected the plane he advised us the correct way to clamp fuel lines and hoses. The "C" clamp must not allow the pipe to rub up against the frame. Hence in most cases when we secured the fuel lines we needed to use two clamps....one joined to the frame and one joined to the fuel pipe and them secured together. This ensures the pipes are not rubbing against anything. Again when we used cable ties we used three different cable ties...one around the frame....one around the cable and then one between the two to keep them seperated.
