Brief Description: Fuel tank vent line installation at wingtip
A simple job of installing nylon tubing to the aux vents, connected with nylon connector insets. The ends of the hose are cut at 45 degrees and fastened with clamps. The end of the hose passes through the bottom of the wing.
Noel Whitticker was over on Saturday and his experience building planes was excellent when we were trying to interpret where the cables case should go. We re-did both wings on his advise and thankfully it was picked up now and not when we were trying to fix the rudders.
