Brief Description: Fit the firewall to the fusealge and drill the tab
Ten tab holes were drilled from inside the cabin onto the firewall. Holes were then drilled into each 90 degree flange and the fire wall. We clecoed the holes as we went. Finally rivetting the flange edge and the flat sheet together with stainless steel rivetts. The rivetts were installed with the rivet head on the forward side of the firewall so from a pratical standpoint the firwall wil be flat and easier to wipe down.
