Brief Description: Fit the fuel lines and install fuel line brackets
We installed the aux fuel pump closer to the auxiliary tank which was away from congested areas. We bent the aliminum tubing with a pipe bender giving nice smooth curves for a even fuel flow. The fuel lines from the auxiliary tank to the main tanks is reasonably straight with a slight bend towards the main tank. Once the fuel pump was secured we tightened the fittings on the pump outlet and the main tank inlet. Where the fuel line crosses the main ribs we installed fuel line brackets.
Geoff Wood from the Gawler Flying Club dropped in today and visited the plane. Geoff is in the throws of building his third plane so his positve feed back was very good. It was also very nice to get another opinion from someone with experience before we closed the wings.
