Tim and Darren Aussie Web Site
Date:  2-4-2008
Number of Hours:  6.00
Manual Reference:  2.114 step 29-32
Brief Description:  Set the Dihedral angle of the wings
After many hours and 5 men twisting, holding and measuring to get it right we achieved the desired 1.6 degrees dihedral angle. This eventually settled at 1.4 degrees. More importantly the string line from each wing tip measured down to each side of the fusealge was identical and measures
4-17/32". Darren rang Harry Delong in the factory in the USA they said we were in the top 90% to get it right. We had a lazor level, digital level and two other acurate levels to get it all right. All sounds very easy but the fusealge must be level on both axis and then you need to get the twist out of the wings and ensure they are 1.6 degrees. Could not have done it without the help of Geoff Quinlan, Peter Koald, Alex Quinlan and Mark Walmsley on the night.
