Eric Seber - Waiex Project
Date:  1-18-2014
Number of Hours:  4.70
Manual Reference:  WIX-F03
Brief Description:  Started Assembling Aft Spar Carry-Thru Structure
In my Waiex kit S/N153, it originally came with non-match hole channel. So I have had to cut everything out of raw channel. When the time came to make the aft spar channel I realized that I didn't have enough of the channel lenght left. I ordered the part which is now match-hole construction. According to the plans, the center hole in the channel is supposed to be at 19 11/16 or a similar dimension (not looking at the plans at the moment). When I measured the hole it is centered on 19 inches. I may have to expand the hole for the ruddervator pushrods in during wing rigging.
Got a lot accomplished today. Pilot drilled, updrilled, deburred, cleaned and primed the aft spar carry-thru assembly. I waited until later this evening and assembled the components. All fit well and this part will go on the shelf with the other attaching parts awaiting wing rigging some day.
Cut Flanged Edge of Aft Spar Channel
Updrilled and Ready to Deburr
Primed and Assembled
