Brief Description: Continued Fitting Lower Seat Attach Parts
While drilling the seat attach cap assy I realized that I was going to have to remove the side panel attach angle bolts (see pic 3) to access the most outboard pilot hole. There won't be enough clearance between the nut and head of a rivet during install, so I'll countersink that hole prior to install. The materail is plenty thick, so no worries about strength.
I also drilled the LH, RH, and Center channel sections to the structure and floor.
