Brief Description: Began Pilot Drilling RH FWD Fuselage Side Panel
After studying the plans a bit more, I started pilot drilling the RH angle components on side panel. The machnined angle components kit parts line up nicely with the side panel. You have to make sure that your surface is flat so as not to build any twist into the panel.
I got through several of the construction order notes tonight. I'll be able to move more quickly tomorrow.
