Brief Description: Installed Nutplates In Floor Supports for Hat Chan
Drilled, cleaned, primed and installed the nutplates for the hat channel fasteners. The floor structure is very thin and the plans call for countersinking that structure. Since there is little material the countersink holes look bad. They will hold fine, but this setup leaves little to be desired.
Tonight I also started cutting the hinge halves for the seat sling.
