Brief Description: Deburred, Cleaned & Primed RH Side Panel Parts
Tonight was a lot of the tedious work. I deburred everything, had to smooth out the laser cut edges of the component kit parts, and then remove all of those annoying part labels. I found that if you run a solvent soaked rag over the label that they become super-easy to remove with a plastic scraper!
I did get to priming and applied two good coats on all the parts. Final assembly starts tomorrow!
