Brief Description: Positioned & Pilot Drilled Aft Fuselage Structure
After figuring out that I had bent the aft LH fuselage skin incorrectly, and re-bending it correctly, I started laying out, positioning and drilling the various parts on the LH structure. Previously, when I bent the LH skin, during plans sheet F27, I looked at the opposite view drawing and bent the forward skin flange out 14 degree instead of bending it in. It is very easy to get this confused when trying to make the opposite side parts. I was able to re-bend this part 14 degrees in the opposite direction without any issues, and it still looks good.
