Rans S-7S Courier
S7S
Wing RH
4-2-2009
05A-04
Wing Frame Assembly
Started with the right hand wing frame assembly.
Bolted the inner and outer compression tubes. Installed the aileron cable rub block and the aileron cable retenion plate.
Installed compression tube doubler inside the bell crank compression tube.
Installed both flap and bell crank compression tubes into the wing frame.
Installed the jury strut bracket.
Installed the door up catch socket and the drag braces.
Installed the bell crank braces.
Installed the tip bow.
Installed the nut plate for the aileron hinge bracket.
Bell Crank Brace
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
