Rans S-7S Courier
S7S
Wing RH
3-28-2009
05A-01
Wing Spar Assembly
Installed the root doubler in both leading edge spars.
Riveted the leading edge patches in place.
Installed the long wing channels and U-Brackets.
Installed the leading edge doubler.
Installed the trailing edge spar root fittings and long wing channels to both trailing edge spars.
Step drilled the 8" hole inboard from the tip end of the left leading edge spar to 5/8" using a Unibit step drill.
Root end
Root end
Tip end
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
