Rans S-7S Courier
S7S
05F-01
Wing-Sheet Metal Installation
Pre-fit the leading edge tip wrap.
Assemble the root stiffners to the top root skin.
Positioned the top root skin on top of the ribs, dilled 30 holes through the root skin top into each rib.
Located the fuel tank filler neck hole, removed the top skin and cut a 4 9/16" hole.
Centered the scupper on the fuel filler neck and drilled 30 through the perimeter holes into the top root skin.
Deburred all parts.
Placed the top root skin on top of the no 1 and 2 rib, rivited the skin to the root rib only.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
