Rans S-7S Courier
S7S
Applying Poly-Brush
After scrubbing the fabric with MEK, followed bij passing a tack rag over the surface to
pick up any dust.
Thinned 3 parts Poly-Brush to 1 part R-65-75 reducer.
Poly-Brush has a pink tint so one can see where it has been applied.
The runs you'll see on the pictures are on the inside of the fabric, this is normal.
Next job will be attaching the patches and finishing tapes followed by two sprayed
coats of Poly-Brush.
S7S Home
810
Control Systems
Covering
Delivery
Gear
LH Wing
Wing LH
Wing RH
