Brief Description: Fuel pump cover, fairings and cowl
Installed and wired cabin light. Used an LED dome light purchased at Advanced Auto and mounted it on the bottom of the subpanel bottom flange. It illuminates the footwell very nicely.
Drilled the fuel pump cover for velcro disks. Pop riveted the disks to the cover. Installed the cover in the cockpit and then applied the carpet pieces to the cover.
Sanded Smooth Prime coat on wheel fairings, langing gear leg fairings and intersection fairings.
Fitted upper and lower cowl to fuselage and did some fnal sanding where the halves meet.
