Brief Description: Panel frame and brackets, mount toggle switches to
Got some odds and endsdone today.
A bracket for the Alternate Air control was fabricated from angle, drilled to the panel bottom angle and riveted. I riveted the panel frome to the panel bottom angle. Also riveted the throttle quadrant brackets to the panel bottom angle and the bottom of the sub-panel. The throttle quadrant was bolted to the brackets.
Drilled screws were used to mount the throttle and mixture control brackets tot he engine and were safety wired.
I brought panel pieces and the toggle switch components home and assembled the switched, affixed labels and mounted these to the panel.
