Attached terminal ends to wires for ammeter shunt, then attacthed them to the shunt.
Drilled holes for the Transponder and ADS-B antennas. Holes were deburred and then antennae were bolted to fuselage with doubler plate inside. Coax cables attached to antennae.
Fabricated and installed the right brake line that runs from the firewall pass-through fitting down the landing gear leg and to the right brake. Tubing was formed to shape, fittings added and ends flared. Fittings coupled and line secured to gear leg and motor mount.
