Brief Description: Cowl hinges, brake reservoir, Vertical Power brack
Cut hinge to length for cowl attachement along bottom of fuselage. Cut shim strip and cut to length. Match drilled hinge and shim to firewall/bottom skin. Parts removed and deburred. Hinges and shims riveted to fusleage.
Brake reservoir drilled to firewall. Holes deburred and reservoir mounted. Inside tube fitting installed.
Fabricated bracket for the Vertical Power circut breaker box to mount the box between the front deck ribs.
