Bills RV-7 Build Site
Date:  7-7-2014
Number of Hours:  4.00
Manual Reference:  SB 2014-1-31
Brief Description:  HS SB
With delivery of a 90 degree drill and bit set from Aircraft Spruce I was able to drill out the rest of the rivets attaching the reinforcement angle and splice angle from the HS main spar. Then I prepared the doubler plates and rib flange angles. The doublers were drilled to the spar and angles, then removed, deburred and primed.
Trim and deburr Spar flange
Parts readied
Parts readied
Rivets drilled out
Rivets drilled out
