Drilled, deburred, and countersunk rivet holes for module attach platenuts on center panel. Platenuts riveted. Drilled and cut holes for flap swith and AP disconnect. Driled holes for bezel plates for each switch. Dynon AP panel, Knob Panel, compass and 2 switches monted to center panel and panel mounted to fuselage.
Set screw drilled, deburred and tapped for control stick grips on both sticks. Copilot grip prepared by soldering wires to PTT switch and assembling swicth and attaching to control. Copilot wire has quick dissconect attached so stick can be removed.
Right panel marked for holes and hole for Hobbs hour meter was cut.
