Brief Description: Install cowl and fairings, install spinner
Got a lot done today. Justin, a local A&P came by and helped (i.e., did) with the safety wiring of the prop hub. This is a difficult task on a constant speed prop as there is lettle clearance to pull the safety wire.
I installed the copilot seat back, then installed the copilot seat and back cushions.
Installed the footwell carpet.
Applied cowl shield to inside of lower cowl, then installed cowl on plane.
Installed the spinner bulkead, spinner fillers and spinned cone using supplied hardware.
