Bills RV-7 Build Site
Date:  6-15-2015
Number of Hours:  6.50
Brief Description:  Panel, Cabin Heat control, Keyed ignition
Cleaned up the switch holes in the left panel. Fitted ignition switch to left panel. Removed panel frame, filed away for clearance with ignition swith, reinstalled frame.
Fabricated bracket for Cabin Heat control and riveted to panel frome bottom angle. Fitted control cable for cabin heat and installed.
Wired ignition switch to VPX and starter solenoid. Installled wire for Master Solenoid and switch.
Cabin Heat control
Cabin Heat control
Keyed ignition switch
