Attached washers and nuts to bolts attaching rudder to VS. This sounds pretty routine but the bolts are kind of hard to get to so it took a while to complete.
Engine mount was bolted to front of fuselage. The attach bolt heads do not interfere with getting a bucking bar in to the front deck attach rivets so I decided to put ion now. I am thinking I want to mount the engine and run all the wiring and cables before I rivet the front deck and while I have easy access behind the firewall.
