Installed the fiberglass tips on the HS ends and VS end using the prescribed pull rivets.
Mounted the VS to the fuselage, hopefully for the final time. Torqued all bolts.
Mounted rudder on VS.
Final drilled rivet holes for rudder bottom to rudder. Deburred and countersunk holes. Drilled and fitted snap bushing in rudder bottom for tail light wires. Attached rudder bottom to rudder using prescribed pull rivets.
