Brief Description: Elevator trim wiring, attach elevators
I finally decided on routing for the elevator trim wire where it goes from the fusleage into the left elevator. Connectors were attached to both ends of the wire, connection made and wire safety ties in place.
Right elevator was installed. I have discovered that is is nearly impossible to get a wrench on the bolts that tie the elevator horns to the center bearing with the vertical stab in place so it looks like I will have to remove the rudder and vertical stab in order to tightnen the bolt.
