Brief Description: Center section bulkheads completed
Today I completed the forward and aft sections of the center section bulkheads. All components were riveted or bolted on as required. The contol column and sticks were fitted and then the sticks removed. The foreward and aft bulkheads were trial fitted together with bolts using the proper spacers.
On completion of this bulkhead I gathered the various parts for the next component, the F-705 bulkhead. This is the bulkhead that is at the rear of the seats. Several parts are fabricated from either bar stock or angle stock and these were cut to length before calling it a day.
